I have begun to delve into a repair of an old CRT Monitor, which I was/am using for my arcade cabinet. I figured this would be a good place to keep track of my progress, as well as get help from all the great minds on this forum. Hopefully this will result in a successful repair!
I should preface this by saying that I am familiar with electronics in general, but have not done much in the way of technician work, or troubleshooting in general, so while I can identify all the parts and understand their basic function, I may or may not entirely understand their purpose in circuit.
I do have the service manual for this TV and I have scanned it into the computer, I will be posting that as it seems pretty important if anyone does get the inkling to offer some assistance.
The initial symptom on this TV Set was a blown fuse, and it ended up just sitting unused for a couple years. I decided it is time to repair it, and so I figured the first step is to replace the fuse and power it up to make sure it wasn't caused by a power surge/lighting strike etc.
The fuse didn't blow again, and I could hear the static/charging of the CRT. I guess that means I have high voltage, so I give it a minute while looking at the back of the set, but noticed no glow from the CRT neck (no heater). That suggests to me that high voltage is working but low voltage is not.
First thing I did was probe the test point (TP9) for the B+ voltage, which according to my manual should be 135v, but its 161v. That's way too high (~20%). I look for a B+ adjustment, but it doesn't seem like this monitor has an adjustment, it guess it uses an IC that should output 135v (STR3035/NTE15012) with no need for adjustment?
A thought occurring to me at this point. Should I try disconnecting the output of the primary voltage regulator from the rest of the circuit and try retesting the output to see if it goes down to 135?
Still, that shouldn't keep the heater from working, as that should only raise the supply voltage on the low voltage supply side by a few volts and the regulators should be rated to deal with a higher supply voltage anyways.
So I check the voltage going to the 12v regulator, which appears to be a series regulator setup using a power transistor (2SD774) and a zener diode connected to the base (RD13Eb2) and to the output through a resistor, to clamp the output to 12v. I got 0v at the base. Just for kicks I check the 9v regulator as well, its a similar configuration, Power Transistor (2SD880) with a zener (RD10EN2). 0v as well. Did the same for the 5v regulator. Same situation. Obviously no low voltage supply at all.
I traced the supplies for these, and they all converge and travel to the flyback, which has an output pin for 12 volts. I test the output of the 12v supply from the flyback, and I am also getting 0v.
I notice that right near the 12 output on the flyback there is a low ohm resistor and inductor in series before it goes off and splits to the different low power circuits, so I disconnect one leg of the resistor to isolate the 12v flyback output completely, and retested the output from the flyback. I figure this would remove the possibility of anything shorting the output to ground or otherwise pulling the voltage down. Still 0v output from 12v pin on the flyback. I checked the H1 and H2 pins and got the same voltage as B+, which seems close to what they should be according to the schematic.
As I said, I am pretty green when it comes to working on TV's. As a matter of course, I pulled the Horizontal Output/Drive Transistor and the Pin Out Transistor and tested them using a diode checker, and they both checked good, no shorts and tested like two diodes facing each other.
That was round 1. So, Right now I am under the impression I need to purchase a new flyback and a new regulator IC. Does this seem like a reasonable conclusion given the information so far?
I plan to pull out the OScope and test a few points in the circuit using a 10Mohm 10x Probe, but I need to find my isolation transformer first. Ill scour the garage in the next day or two.
Thanks for any tips/tricks and information, if you so choose to throw some knowledge at me.
Lastly, apologies for any crudity in the schematic image, I had to scan it bit by bit and then stitch it together in photoshop, despite not having used photoshop since college. I have the block diagram and board layout if those are needed, though I would need to stitch them together as well..
