Author Topic: LCD Backlight IC  (Read 1423 times)
Offline jmajtyka76Topic starter
LCD Backlight IC
« on: January 27, 2016, 04:34:42 pm »
Hello I repairing a Flir b60, the lcd backlight is not working I have checked voltages to the IC/Driver. The flat flex is fine tested good, I have traced the following error to this IC/Driver, I know its part of the led driver but I don't know who makes it if anyone can identify this part I appreciate you help.
James M.
Offline Buriedcode
Re: LCD Backlight IC
« Reply #1 on: January 27, 2016, 10:41:36 pm »
http://www.futurel.bg/datasheets/4/HV9903.pdf
:D
Supertex chip, apparently they were acquired by microchip.  I couldn't find a datasheet from a 'nice' site, the copy from mouser gave an error
« Last Edit: January 27, 2016, 10:59:50 pm by Buriedcode »
« Reply #2 on: January 28, 2016, 03:34:48 am »
Thank you, the data sheet will help me to find a suitable replacement...
