Hi folks,
I've got an Apple Mac that I'm working on, due to configuration issues I'm not able to connect the Analog Board (w/ PSU), Motherboard and CRT all together. One of the voltages from the PSU is slightly low so I'd like to run it with some load - the only problem being that the motherboard connects to the PSU via. the Analog board (which has the Flyback transformer).
Do I risk any damage to the Flyback transformer powering it on disconnected from a CRT?
