Author Topic: Mouse rotary encoder [Mad Catz MMO 7]  (Read 5504 times)
Offline TomTomminsonTopic starter
« on: August 21, 2015, 06:55:16 am »
Hi guys,
do you know where I can find a rotary encoder like this for my mouse?
Here some other pictures of the product:
http://www.overclockers.com/forums/showthread.php/753083-Fixing-Mad-Catz-M-M-O-7-double-click-issue-DIY
Thank you!
Offline Rasz
    • My random blog.
Re: Mouse rotary encoder [Mad Catz MMO 7]
« Reply #1 on: August 21, 2015, 03:20:34 pm »
alps makes this type of encoders
Offline Gyro
« Reply #2 on: August 21, 2015, 09:19:42 pm »
Silly as it may seem, another mouse?.... An old Genius optical mouse uses this type of mechanical encoder, if you can find one. One that looks like this:
Edit: A PS2 one
http://www.penguinunitedforum.com/viewtopic.php?f=3&t=5287
You could also try removing it and cleaning the contacts.
« Last Edit: August 21, 2015, 09:28:04 pm by Gyro »
Best Regards, Chris
« Reply #3 on: August 22, 2015, 04:54:25 am »
Yes, thank you! the seems to be the right place! Now I've to find a dealer.
Thank you too! It's not silly, for the click button, in example, I've used another mouse couse most of good mice use an Omron micro switch.
But rotary encoder may be very different from one to another, at least in dimensions and pin configuration. I'll try to look for in every mouse I open.
I'll do it of course, but first I need a replacement, couse it's so small and something can always go wrong.
Thank you all for answers! :-+
Offline rvalente
  • Country: br
« Reply #4 on: August 22, 2015, 03:05:08 pm »
Does he still makes the characteristics rotating noise? Maybe the spring broke...
Have you tried to spray some contact cleaner? You may have a mix of dirty, oxide, sweat and fat grease inside...
Some rubbing alcohol (isopropanol) may helps to..
Offline Gyro
« Reply #5 on: August 22, 2015, 04:00:04 pm »
I was going to suggest some IPA too but I couldn't think of a polite way of describing the possible contents of the encoder, that you have managed to do so well   :-DD
Best Regards, Chris
« Reply #6 on: August 24, 2015, 06:28:27 am »
Nope, the problem wasn't the noise. It's like you scroll down on the page and, on a random number of scroll, it scrolls up for one or two steps. Or viceversa. It was very annoying!
I've cleaned with alcohol and now seems to be all right! But, you know, it's better have a replacement in home if this component is a trouble one.
I haven't find yet the same exact model of rotatary encoder that is now in the mice.
Thank you all!
« Reply #7 on: November 07, 2015, 05:59:42 am »
After searching, buyng and comparing... as you said in the first answer, this is the boy:
http://www.alps.com/prod/info/E/HTML/Encoder/Incremental/EC10E/EC10E1220501.html#Photo
Thank you all!
Offline Gyro
« Reply #8 on: November 08, 2015, 02:12:13 pm »
Good of you to come back and let us know! :-+  Far too many threads die open-ended.
Best Regards, Chris
