Author Topic: Multimeter ANENG AN8002 failed on testing continuity please help.  (Read 401 times)
Offline SpyTattoo
  • Country: th
AN8002 failed on testing continuity no beep, sometimes show resistance value(53 ohm). If i testing on diode still work perfactly.
Do someones have experience for this error of multi-meter.
Thanks in advance.
Offline floobydust
Re: Multimeter ANENG AN8002 failed on testing continuity please help.
« Reply #1 on: January 12, 2018, 08:25:28 AM »
Spin the rotary switch a few times, it might be oxide on the switch.
Offline SpyTattoo
  • Country: th
« Reply #2 on: January 12, 2018, 08:52:48 AM »
I already do it many times but it's not work. Try to change both probe too but no luck.
Thanks for reply.
Offline retiredcaps
« Reply #3 on: January 12, 2018, 09:49:56 AM »
I don't have this meter, but maybe take it apart and look for any obvious signs of problems?  Bad soldering, some debris inside?
I suspect the cost of returning this meter to whereever, unless locally, you bought it will be more than the cost of the meter?
Offline stj
« Reply #4 on: January 12, 2018, 09:50:32 AM »
it wont beep if it's over 50ohms.
put a wire between the sockets incase the leads are bad.
Offline RayRay
« Reply #5 on: January 12, 2018, 09:53:19 AM »
You mean you've literally changed em, or only switched their positions? Just wanna verify I got it right (as your English isn't the greatest)
Anyhow, provided you did try different probes, I'd say it's either a faulty buzzer, a bad solder joint, or a faulty component.
You'd have to open it up and have a good inspection (and possibly some testing with another DMM) to get more insight.
Offline stj
« Reply #6 on: January 12, 2018, 12:48:52 PM »
well the buzzer should beep when you turn it on or switch ranges/modes
so that's easy to test.  :)
Offline Electro Detective
« Reply #7 on: January 12, 2018, 02:03:30 PM »
Maybe the internal fuse is wacked out,
I fixed a similar cheapie meter the other day that has shared 200ma current and V  \$\Omega\$  socket
The fuse looked ok but failed on the test
The following users thanked this post: SpyTattoo
Offline SpyTattoo
  • Country: th
« Reply #8 on: January 13, 2018, 08:44:19 AM »
Could you please tell me where is internal fuse?
Many Thanks..
Offline barry14
« Reply #9 on: January 13, 2018, 08:58:42 AM »
The fuses are the 2 components at the bottom of the board labeled F1 and F2.
Offline Armadillo
  • Country: sg
« Reply #10 on: January 13, 2018, 06:07:37 PM »
Have you Re-solder the connector sockets and joints?
Flimsy board can't take mechanical stresses.
« Reply #11 on: January 13, 2018, 08:48:05 PM »
My money is on the 600ma fuse on the left gone zapski...
If it is blown, where is OP SpyTattoo going to get one of those halfassed circus sideshow midget fuses with the correct value of 600ma?  :-//
What were they smoking at the ANENG design (save money) meeting for this meter?   :palm:
Online amspire
« Reply #12 on: January 13, 2018, 09:02:31 PM »
« Last Edit: January 13, 2018, 09:19:55 PM by amspire »
Offline SpyTattoo
  • Country: th
« Reply #13 on: January 13, 2018, 10:13:10 PM »
Thank you everyone i will search genuine 600mA fuse first if they not sell i will buy new clone one.
First i must re-solder socket.....
Thanks all...
Offline Armadillo
  • Country: sg
« Reply #14 on: January 13, 2018, 10:55:07 PM »
Thanks all...
Hi, remember to plug in both the probes into the sockets when you solder so that the rings will stay concentric when you solder the joints. Hope you understand what I mean.
Offline stj
« Reply #16 on: January 14, 2018, 08:14:25 PM »
Is the 600ma fuse confirmed blown?  :-//
Offline SpyTattoo
  • Country: th
« Reply #17 on: January 14, 2018, 10:00:34 PM »
It is not blown. I remove fuse and wire jumper directly not solve problem.
Is it another problem?
Do you have a schematics for this meter? Thanks
