So I recieved a camera that the previous owner said wouldn't power on because the power toggle switch stopped working. For a bit of background the camera switch looks like this.
You kinda push the little thing around at the front which rotates the whole thing.
Inside the camera its a rotating metal thing that has a vertical post circled in red here:
Note the holes and the spring loaded "selector" thing at the top that gives the toggle its rigidity and feel and stuff. This is is the config when the switch is ON. So to turn off it would rotate clockwise. The PCB directly under this looks like this.
The square silver thing is directly under the gold coloured centre part of the toggle switch. I assume that it doesn't actually always make contact with the metal plate because it's actually a shutter button with a half press feature (which is what I assume the springy metal thing is for). That messed up black box sits adjacent to the vertical post I circled earlier, in fact I took these two images and overlaid them to give myself an idea of how it actually fits together.
Hopefully its not too hard to see. So note here that the switch is set to ON which means when its turned off, it actually moves closer to the black box thing and I presume more parallel to its orientation. I assume that the previous owner (or some random person) has actually fiddled with the switch and actually removed some of it because obviously it's not doing anything.
I measured the voltages across the two terminals on either side. It's 2.5v. I hope this diagram makes sense.
I realise this is a bit of a stretch but has anyone seen a switch configuration like this? I took a look through another Fuji camera's service manual (none found for this particular model) where there is a similar switch and the boardview showed two seperate kind of contact switches shown here:
Maybe this camera is the same where OFF shorts one set of terminals and ON shorts the other. It'd be harder to bodge that repair then.
I'd really appreciate ANY help I can get! I'm not an expert by any means but I'm hoping and praying that I can get this camera working (it's a really nice one!!!).
Full album here:
https://imgur.com/a/swONXThanks!!
Kevin
P.S. Sorry about the massive images, I even tried editing them in imgur but they refuse to change on the forum. Maybe it's something to do with a cached preview.
