I am going to drop a bomb right here... one of the other 222five that has both channels working reads exactly the same as all this last measurements!!! Now, THAT´S weird.
one thing I just found out is that with the beam finder pushed the vertical position control does not change the trace, but in channel 2 with the beam finder pressed it does vary the trace position. Channel 1 position pot does vary resistance tho.
