Author Topic: Reball "repair" (the Rossman video and such)  (Read 1419 times)
Online wraper
  • Country: lv
Re: Reball "repair" (the Rossman video and such)
« Reply #25 on: June 22, 2018, 09:06:05 pm »
Also, dear wraper, BTW, how do you think Apple itself fixes these mlbs? They do exactly the same thing...
Blast with a heat?  :palm:. Unlike you and me, Apple has a source for new chips. Not to say they do it somewhere in a big factory, not small repair shops. You can get many but not all (non faulty) chips, they origin is questionable and therefore hit and miss.
Online GeorgeOfTheJungle
« Reply #26 on: June 22, 2018, 09:38:57 pm »
Exactly, replace the chip... with a new faulty chip.
Online wraper
  • Country: lv
« Reply #27 on: June 22, 2018, 10:02:27 pm »
Say unreliable nvidia chips from 2006-2008 got an update in 2009 and were not failing anymore. Dunno about later chips but they probably got an update as well. Even if they replace them with the same chips which are prone to failure (not faulty), not 100% of them will fail. If they will eventually fail, you can at least expect they will last comparably as long as original chip lasted. If you blast the chip with a heat, it's still the same old chip which is still faulty.
« Last Edit: June 22, 2018, 10:04:33 pm by wraper »
« Reply #28 on: June 24, 2018, 12:42:44 am »
http://www.youtube.com/watch?v=AUaJ8pDlxi8&feature=youtu.be&t=11m36s
« Last Edit: June 24, 2018, 12:45:35 am by GeorgeOfTheJungle »
