So remember I had ordered new parts - the transistors, the 10 ohm resistors, and 22 and 10 uF tantalum caps. The original failure burned the two 1/4 W 10 ohm resistors and also I found the 10 uF tantalum caps had failed, but I didn't find any other failures even the two output transistors checked out good.
The first things I replaced were four 22 uF tantalum caps, and checked it at that point and it worked OK. I then replaced the rest of the components in the output stage I ordered and turned it on and the magic smoke started coming out of the 10 ohm resistors. I turned it off before they were damaged too much to continue troubleshooting. I then pulled the last two transistors from the sockets and turned it back on and it worked OK even without the last two transistors.
At this point I was befuddled. I studied the schematic again and couldn't see what else it could be since I had checked most everything else in that area. I then inspected the board again and I noticed that the two new 10 uF tantalums I installed were discolored. I pulled them and found they were now bad. They both measured something like 45 - 55 ohms and failed the capacitance test.
So did I install them backwards? Nope. So what happened? I turned my attention to the rest of them in the bag I bought - 10 total. About half of the "new" caps tested bad! Bad as in they had no capacitance only resistance. So this is very very odd, that the original failure was bad tantalums
and the following failure was the same using what was supposed to be new tantalum caps.
I decided I wouldn't use any of the 10 uF tantalums I bought, even though half of them tested OK. I installed two 10 uF electrolytics and the thing is humming along now like a finely tuned engine for the last hour up to 10.9 MHz.
I will now write a message to the seller of those 10 uF tantalums asking for a refund.
Also I'm now confident this part is done and will shorten up the transistors leads and re-re-install two new 10 ohm resistors.
Now I can move on to the calibration procedure and lastly the cosmetics/cleanup.
OK johnny10 - your turn.
You can use this thread if you need any help or measurements.
