Well, channel A gives me a trace on screen now.
The problem was that the trace from a 2V Zener-Diode, which is responsible for providing a -2V Rail for the Substrate of the P2CCD-Chip via R8089, was interrupted by corrosion right next to the solder-pad of R8089 (see pictures).
I bet destroyed traces were also the problem with the PM3323 I tried to repair earlier, which then failed rather spectacularly
The symptoms were pretty clearly centered around the P2CCD-Chip of Channel A (with the added problem that my Scope-Probes sometimes had problems breaking through the oxide-layer of solder joints), with Channel B working sort of (Noise and jumps of the trace at timebase-settings slower than 200µs/div).
Using Channel B as a reference, I walked through the entire signal-chain and discovered that the outputs from the P2CCD-Chip of Channel A were at the same DC-Level, but their amplitude was 10x higher.
With everything set exactly the same on the input, I started focusing on the output-side and then the supply of the Chip - I know: Supply should be checked first, but because everything else around the chip worked, I assumed supply-voltages to be ok.
After repairing the trace, Amplitude of the outputs was basically the same on both channels and by following the procedure for the pre-adjustment of the P2CCD-Chips I managed to get the picture on my measuring scope that is specified in the Service-Manual.
Searching in Forums, it seems a lot of people have the same problem (Channel A or B being outside the screen), but nobody wrote about the cause, so hopefully this will help others fix their scopes: Channel A / B being outside the screen = Check Substrate-Voltage - Mine is at -1.409V and pretty much the same on both channels.
Next I'll check why the 14V-Rail is only at 13,15V and if there are other rails that are out of spec. I haven't seen much noise on the supply-rails so far. At least on the P2CCD-Unit the rails seem pretty clean.
What can I do btw. to prevent any further corrosion? I've cleaned all areas with a brush and Alcohol and during soldering I used large amounts of no-clean Flux. Is that enough or are there additional methods I could try?
