So Im in the market for a variable power supply and thought I'd spend the extra dollars and get the rigol DP832 over some other more basic cheaper units I was lookong at. It arrived yesterday and switched it on, no loads connected, channel 2 & 3 seem to work sweet, channel 1 however does not output the preset voltage. The actual voltage at the terminals should be displayed on the LCD screen, but reads 0V no matter what the preset voltage is set to, and displays UR (unregulated) where the other channels display CV, or CC. It seems there is a fault preventing channel one from supplying any voltage/current whatsoever. The place i bought it from are suggesting I fix it and they reimburse me for it. Has anyone experienced this same problem with these power supplies? I understand they are a good
power supply whilst they are working but have heard of a few faults with blowing series pass transistors etc when shorting the terminals (even though they should be current limiting) I dont want to be having to
open and fix a brand new lab grade power supply i payed good money for, especially because itll void my warranty. Interested to hear peoples thoughts on what the issue could be.
