Author Topic: Rigol DS1054z offset problem  (Read 3169 times)
Offline martin.sTopic starter
  • Country: sk
« on: March 10, 2016, 06:21:36 pm »
Hello there,
I have a problem with my Rigol DS1054Z.
When I measure DC signal with CH2 I found problem with offset.
You can see it in print-screen and photos.
I tried to change probes, re-calibration in setup menu.. everything else.. and phenomenon still persist.  :-\
Without any signal there is without any offset.
Do you have some solution for it?
Offline Bud
Re: Rigol DS1054z offset problem
« Reply #1 on: March 11, 2016, 03:25:45 am »
You may get a clue from Part 4 of my thread here once I post it:
https://www.eevblog.com/forum/projects/project-yaigol-fixing-rigol-scope-design-problems/
But you have to wait a bit for it.
Offline JFJ
« Reply #2 on: March 11, 2016, 01:16:48 pm »
I tried to change probes, re-calibration in setup menu...
Have you tried re-calibrating with the channel inputs shorted to ground? Also, don't forget to let the oscilloscope warm-up for 30-minutes before re-calibrating.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
