About 6 months back I got a Rigol DS2072A and immediately hacked it. It worked with no issues for a few months, after which I did not have time to use it much.
Today, I go to power up the scope (the green LED on the power button is pulsing on/off) but the scope would not turn on. Before I take the screwdriver to it to start debugging, I was wondering if anyone had a similar experience with their scope.
I can't imagine anything past the power button is broken, maybe the soft switch is not making good contact, as the power supply seems to be lighting up the LED.
Any ideas on what I should look at first? Based on posting this in the Test Equipment forum, this does not seem to be a very common problem.
Regards,
Andrei
