Ok, I followed your advise retiredcaps. Did a little scrubbing with vinegar and a toothbrush, followed by a mixture of backing soda and water to neutralize the acid in the vinegar. Wrinsed with clean water, then dipped in IPA and scrubbed a little more with a toothbrush. I then sit it out in the hot West Texas sun for about 8 hours so it should be dry as a powder house fart now. As for the "0" adjust pot, I pulled it from the board, soaked it in vinegar, then baking soda, wrinsed, then IPA. Sit it out in the same blistering hot sun. It now reads correctly on a DMM. The only damage I see is that it removed some of the resistor and diode numbers. No worries there, I have a full schematic, and parts list. Other than that everything is good.
Next delima is the wirewound resitors. The sheathing on the wire is green so i would assume that the wire inside the sheathing is green. They all ohm out to spec, but I am betting in the long run they will fail. Any idea where I can find them? Values are: 0.452 ohms, 2 ohms, 11.2 ohms, and 22.5 ohms.
