From what I can see of the upper side of the board I have sketched-out most of the circuit. Note - it is incomplete - there are tracks that disappear under the IC and under the current transformer - I can't guess where they terminate. I have also had to make several assumptions about the termination of partially obscured tracks - i.e. NO GUARANTEES of accuracy of this schematic. Happy to make corrections to the schematic if anybody has the information.
However, from what is visible it would appear that the tantalum capacitor that you have already removed on the underside image of the tracks went short-circuit and took-out the resistor. The resistor is decoupling the mosfet driver stage from the higher-voltage supply - so it's value is relatively unimportant - I would guess at 47, but it might be 4.7
The diode that you highlighted with the blue arrows has one end attached to a 4R7 (to ground) and its other end attached to the current transformer (also to ground) - so you will measure very little resistance across it in circuit.
