recently bought a pretty pricey (well over 2000 USD) piece of gear from ebay ... the owner warned me there were probably some electrical issues with it despite it having had service previously but it's a very complicated piece of gear - a '79 era studio digital delay unit made by AMS. At any rate - when i first got it in I decided to fire it up to see what it was doing - it ran FINE for the first several minutes - then POOF!! one of the PS resistors flamed out just like a struck match.
Now unfortunately SMPS' are a bit confounding to me - I've read lots about them and watched tons of repair videos on youtube but it still seems like a black art to me and I've only just got my head around linear PS's to the point where I'd have a good shot at designing one.
Since i had a resistor flame out - i'm a bit scared to try to fire it up again lest i do any more damage to the boards inside (not so easy to disconnect the PS from the rest of it since half the SMPS is on the 'motherboard' to which 10-12 large 'daughtercards' are attached to.
But preliminary investigation shows that the SMPS controller IC (SE5560) has the current limiting signal pin shorted to the GND (big surprise right? haha) - the tantalum (1nf IIRC) attached to that pin is also shorted and there's a bad diode attached to THAT. I'm assuming maybe the IC controller had a spike that shorted the tantalum and took out the diode and resistor - OR the diode started the problem... at any rate - I think i have a decent start on this and should replace the SE5560, diode, tantalum and the resistor - but I am wondering if maybe there are other places I might look for damage (?) like in the rectifiers or whatever (or are those mosfets?)
ALSO the flamed out resistor is now open and since it burned up I have NO WAY of knowing what the value of the resistor is. There are NO schematics or service manuals available unfortunately!! and the the only person who does repair on these units refuses to release info on them but WILL look at defective units for a flat fee of USD 1400
can ANYONE help??? i would be very grateful.
note: I've already gone over the whole board and found no other obvious problems - at least in-circuit but I do plan to replace all the electrolytics pictured as well - i would just like to put together a bill of materials for this repair.
John T
overall board view
flamed out resistor
AC reservoir (?) side of things on lower board
