Some time ago, I had the opportunity of buying 2 Solartron 7061 7.5 Digit Multimeter. They were sold for parts and only tested for power-up only.
The Devices:The Solartron 7061 was sold in late 80's as a fast and accurate (7.5 digits) multimeter. It can capture 1500 readings per seconds, got an interesting set of math functions and has some scanning capabilities (with the second input or an extension card).
Both of the units I bought were built in 1988 and are equipped with the revised PCB 13 & 15.
![](https://www.eevblog.com/forum/repair/solartron-7061-teardown-and-repair/?action=dlattach;attach=621844;image)
The Problems:Unit #1:
- Failing 0V Test.
- A little bit unstable. At 6.5 digits the 2 last digits are jumping quite a bit.
- VDC is off (the only thing tested).
Unit #2:
- Pass selftest.
- Readings are erratic. Ex, if 10V is applied at the input, readings will somehow increase but never reach 10V. If the input is shorted, readings will go down but never reach 0V.
