Hi!
Diodes are sometimes colour–coded to denote their type as it's slightly more durable than coding with numbers – for example, a 1N4148 general purpose diode is coded yellow (first band much wider to Indicate cathode,), then brown, yellow, grey = wide yellow = 4, brown = 1, yellow = 4, grey = 8.
Another commonly found example is the Philips BAW62, with a light blue body and a thin blue band and thin red band close together at the cathode end to denote the '62'.
Colour–coded 1SS119s would be coded two brown and one white band, and so on.
However some Japanese diodes (typically "Rohm") used ONE colour band at one end to denote cathode, and also the type of diode, one scheme in use being:–
BLUE cathode band – standard recovery. GREEN cathode band – fast recovery, RED (sometimes WHITE) cathode band – Schottky rectifier, ORANGE cathode band – zener plus a marking to indicate Vz, data sheets need to be referred to for these types of devices as there's many variations!
If youy'e stuck, show us.a picture and any of us on this Forum'll be glad to help!
Chris Williams
