Author Topic: SOT23-6 with marking code 05 or O5  (Read 9573 times)
Offline icezebraTopic starter
« on: February 07, 2023, 08:37:32 pm »
I have tried a lot of things, such as the ideas discussed in:
https://www.eevblog.com/forum/chat/(tips)-how-to-identify-smd-devices-from-the-marking-codes/msg4683560
However I cannot identify this TSOT23 six pin device (SOT23-6) with marking code 05 or O5
It might be a TVS, or a Linear Regulator, or a FET.
It is NOT TVS SMS05
Also, what is the long black thing marked EAUE in the second photo?
Help!
Offline mariush
Re: SOT23-6 with marking code 05 or O5
« Reply #1 on: February 07, 2023, 09:50:21 pm »
It looks like the bottom 3 pins are connected together, so that makes me think it may be a n-channel mosfet on npn transistor.
As for that rectangular black part, it makes me think it's be a shock sensor or orientation sensor, maybe to detect drive falling or something like that.... but it's much more likely it's just an oscillator / crystal, based on the two ceramic capacitors that seem to be connected to the pads at the end
The chip under it is probably a 2 gbit slc nand chip from Micron.
The following users thanked this post: icezebra
Offline fzabkar
« Reply #2 on: February 07, 2023, 10:14:16 pm »
« Last Edit: February 07, 2023, 10:16:15 pm by fzabkar »
« Reply #3 on: February 08, 2023, 12:50:13 am »
Much obliged for the responses so far.
I should mention that the chip next to the "05" SOT23-6 devices is an SMPS synchronous buck controller MP1657 with two internal MOSFETs.  One internal MOSFET is doing the function of the free wheeling diode in a normal buck converter and the other is the "switch" in a normal buck converter.  I have no idea what the external SOT23-6 "05" devices are, but I do not think they can be operated by the MP1657 (for which I append the datasheet.)
On other places on this PCBA there are linear regulators near the SMPS presumably to further regulate the output of the SMPS.  There are a total of 6 SMPS and 2 Linear regulators on this PCBA not including the two 05 devices.  Cray-cray.  See new photos attached for more detail.
https://en.wikipedia.org/wiki/Buck_converter
Also, your are correct, that IS a FLASH device. This PCBA is the main Linux Processor PCBA of a Reolink RLC-510WA IP Camera.  I think it has both NAND and NOR Flash onboard.
So the black thing is likely a crystal then. Good observation with the caps and the proximate FLASH device.  I don't think it is an orientation sensor but I suppose it could be a reed switch or a shock sensor.  I will stick a scope on it if I get the PCBA working again, and update this thread with the result.  The MP1657 has failed and I ordered a new one today.  I was trying to determine what the 05 devices were in case I also need to replace them.  Since they could be FETs I was reluctant to probe them without knowing the pinout.
More info here:    https://ipcamtalk.com/threads/reolink-hardware.68214/
« Last Edit: February 08, 2023, 12:56:03 am by icezebra »
« Reply #4 on: February 08, 2023, 12:53:28 am »
MP1657 Datasheet
Offline fzabkar
« Reply #5 on: February 08, 2023, 01:35:30 am »
Could those be protection devices for the SD card, perhaps an ESD diode array (3 signal lines per chip)?
There is a row of 7 pads behind the card socket on the other side. I suspect there will be continuity between each signal pad and one of the "05" pins.
« Last Edit: February 08, 2023, 01:52:55 am by fzabkar »
« Reply #6 on: February 08, 2023, 05:25:18 am »
@mariush, thanks to your insight with the capacitors I have identified the back EAUE thing as a "Low Load Patch Crystal" part number MC-146
https://www.aliexpress.com/item/1005002886890490.html
https://www5.epsondevice.com/en/products/crystal_unit/mc146.html
@fzabkar that is some brilliant detective work.  I suspect your are very likely correct.  I will measure the devices with a diode checker.  I will not have access to them again until March.  In the interim, I will search the diodes on Ali-Express!
Thank-you to both of you for taking a genuine interest in this, I greatly appreciate your kind assistance.
« Reply #7 on: February 08, 2023, 05:42:28 am »
I want to say SRV05.
On-Semi and LittleFuse and Semtech all make it with different markings.  The Semtech marking is V05
https://www.aliexpress.com/item/1005004126847506.html
https://semtech.my.salesforce.com/sfc/p/#E0000000JelG/a/44000000MCn6/BeAzV1kgq8LEQB.FR71VkMB1v3NUxVrSyFjXw9p4pnk
Offline fzabkar
« Reply #8 on: February 08, 2023, 06:16:29 am »
Congratulations. I was thinking that it may be a "tuning fork crystal" or "watch crystal".
Offline gamalot
  • Correct my English
    • Youtube
« Reply #9 on: February 08, 2023, 05:59:57 pm »
I can't find a component in a SOT23-6 package marked 05, maybe a compatible part for SMS05.  :-//
https://semtech.my.salesforce.com/sfc/p/#E0000000JelG/a/2R0000001OfW/uM7qnDGNH0YlhXQ3LfpChJNLPGRP1iIkH1Mh_q3hrxM
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
« Reply #10 on: February 09, 2023, 10:22:58 am »
Indeed professor @gamalot indeed!
An equally probable candidate to the one last proposed (SRV05).  The reason I ruled SMS05 out in the first post was because the marking is 05/05
https://www.aliexpress.com/item/4001089229496.html
In hindsight, perhaps that was a bit hasty, as the SRV05 fits no better, with a marking of V05
They both have a similar pinout, with one measurable difference.  On SMS05, there is a short between pins 2 and 5. Therefore, as soon as I can get an ohm meter on it (March 2023) I shall report the outcomes, including possible connection to the SD card as postulated by Dr. @fzabkar
I am greatly encouraged by all the engagement and support in this thread.  It is a rather pedestrian challenge, yet you have all deployed the full force of your deductive reasoning and SMD marking research skills.  As as a result we have had some breakthroughs and some great leads to be followed up, not to mention the learning and skill/knowledge transfer that has occurred as a result, which benefits all members of this forum as well as future Googlers.
Sir Isaac Newton summed up this sort of community support and intellectual tag-teaming rather nicely:
https://en.wikipedia.org/wiki/Standing_on_the_shoulders_of_giants
« Last Edit: February 09, 2023, 10:31:21 am by icezebra »
