Hi Armadillo,
After removing Q10 I'm getting all kind of weird readings, please see attachments.
All its left now is to order C01, C05, C06 and U01.
I'll post new measurement readings after swapping the parts.
Thanks!
Hi;
Firstly, as a double assurance, with the power off, please measure the ohms of the following resistors to confirm somewhere near to its value ; R02, R03, R04 and R05.
Secondly, as a double assurance, measure ohm [multimeter] across C02 which is 220pf, just to be sure its very high ohms and not short circuited.
Those as silly steps but double assurance before you change the U01 which looks defective. With 50 Hertz input, I would expect output to be 28vpp and not 2.8vpp. [worth to double ensure that the probe attenuation is set correctly example 1:10? on the probe and on the scope setting.]
Digital oscilloscope - for every measurement, if you cannot see any waves which you expected, then it is worth to press the "AUTO" or "AUTOSET" button on the oscilloscope because sometimes the "trigger" setting is not correct for the signal. I don't know if Rigol scope you are using label it as AUTO?. Do read the user manual about this.
So after you changed the components [C01, C05, C06 and U01], definitely to a re-measurement and expect the output to be ~28vpp if the input is the same as before.
No rush. Take your time
Edit: Forget to tell you, after you have replaced those components, remember to set signal source from zero volume up slowly before you blow the speaker. Your current input is overkilled. Do note!
