Hello folks,
I have one this guys (
https://snag.gy/Zr85Dn.jpg). This relays are used to serve interface between microcontroller and schematic power (110V). This means which are used on rather higher frequency during work. It is frequently this relays burn/broke your command contacts. I am thinking substitute this little guys to relays solid state. I think that best solutions because I will eliminate the spark (when command contacts connect) and I will have a component which will be work very better on higher frequency. What do you think about this?
I have another question. Exist any model the solid state relays which I can use on this bases (
https://snag.gy/zXFVKl.jpg )?
Note: I haven't search yet on producer (which I will also need discovery which are) if this relay bases will give to the solid state relays. Since the bases are of the Finder I think it is better first place to search, what do you think/suggest?
Thanks
