On these models (actually, both Reveal and Precision 6D/8D's), the most common issue is one or both of the 5W ceramic dropper resistors ahead of the voltage regulators failing open-circuit.
The brown glue drying out and turning corrosive and conductive is a ticking time-bomb, and the switches can go wonky too.
Most recently, the 80Hz high-pass switch on one of my Precision 6D's had kicked the bucket, after i took the back off to take care of an intermittent contact on the tweeter output connector.
Nothing a squirt of contact-cleaner and 20-30 operations couldn't fix
You can find the schematics here:
http://91.121.194.115/tannoyschematics.zipThe filter board is almost definitely the same. The only (electronic) difference between the 6D and the 8D is that the 8D has two bridged LM3886's driving the woofer, where the 6D only has a single one.
I hope this doesn't violate any forum rules, but there's a considerable-ish thread on this subject over on the badcaps.net forums:
http://www.badcaps.net/forum/showthread.php?t=16644
