Hi GAD well that was unlucky, but lets bust a few myths...
First myth: You don't need to degauss the CRT, there isn't enough steel in a 2211 to generate any sort of magnetic field, and even if there was a stray magnetic field, it would shift the entire trace in one direction only, and it's probably got a MuMetal magnetic shield.
Second myth: A 60MHz CRT isn't going to have a post deflection mesh accelerator, they're only found in scopes with high bandwidth CRTs 400MHz and above.
It's a 60MHz scope tube NOT a magneitically deflected colour CRT with a shadow mask.
It looks a lot like some interaction between the X and Y amplifiers for some reason. I don't have a 2211 service manual so I can't look up the CRT part of the schematic. Many scope CRTs have a slotted acceleration electrode between the Y and X plates, Y electrodes are first in the beam path followed by slotted accelerator/screen electrode and then the X plates. If your CRT has this extra electrode between the Y and X plates check that it isn't floating. Check for dry joints on the CRT connector board.
Good luck
