Hi neo,the TL866 supports the DS1225 (RW) as stated here:http://www.autoelectric.cn/minipro/miniprosupportlist.txtbut not the FM16W08. Best,0xfede
I can't find a programmer to support the FM16W08, at least not under 200 bucks, and so i guess batteries it is then. Changing a 20 dollar chip every decade or so is a slightly easier cost to swallow.
Quote from: neo on March 23, 2018, 09:51:46 pmI can't find a programmer to support the FM16W08, at least not under 200 bucks, and so i guess batteries it is then. Changing a 20 dollar chip every decade or so is a slightly easier cost to swallow.As the BBSRAM DS1225Y in this 2465B is already proven to survive and keep running in decades even beyond it's designed life, just buy few spare of them, as it's internal battery is only activated when used for the 1st time. So theoretically these should last probably your life time.
Quote from: BravoV on March 24, 2018, 02:11:22 amQuote from: neo on March 23, 2018, 09:51:46 pmI can't find a programmer to support the FM16W08, at least not under 200 bucks, and so i guess batteries it is then. Changing a 20 dollar chip every decade or so is a slightly easier cost to swallow.As the BBSRAM DS1225Y in this 2465B is already proven to survive and keep running in decades even beyond it's designed life, just buy few spare of them, as it's internal battery is only activated when used for the 1st time. So theoretically these should last probably your life time. Only two small problems with that;How do you guarantee they have not been activated before reaching me?Nominal battery self depletion is equivalent to load
Quote from: neo on March 24, 2018, 02:15:33 amQuote from: BravoV on March 24, 2018, 02:11:22 amQuote from: neo on March 23, 2018, 09:51:46 pmI can't find a programmer to support the FM16W08, at least not under 200 bucks, and so i guess batteries it is then. Changing a 20 dollar chip every decade or so is a slightly easier cost to swallow.As the BBSRAM DS1225Y in this 2465B is already proven to survive and keep running in decades even beyond it's designed life, just buy few spare of them, as it's internal battery is only activated when used for the 1st time. So theoretically these should last probably your life time. Only two small problems with that;How do you guarantee they have not been activated before reaching me?Nominal battery self depletion is equivalent to loadOf course no one could guarantee that, but assuming you don't buy from eBay as most cheap ones are salvaged or dodgy relabeled stuff.Mine was purchased from Digikey, as last time it was quite fresh from the factory looking at the date code. It was just one or two months back from the purchasing date.Its very unlikely someone at Digikey was tinkering/playing with it before sending it to you.
