I checked the power supply's five large filter caps with my ESR meter. The filter cap on the -8V rail, C4419, tests bad as open. The instruction manual describes this cap as: Cap., FXD, ELCTLT: 5000UF, +100-0%, 25V. The Tektronix part number is 290-0571-00.
The power supply circuit's unregulated -8V tests as +0.52 volts near the bridge rectifier, CR4411.
I'm not sure if those test results indicate that both the filter cap and bridge rectifier are bad or just the filter cap.
I checked Mouser Electronics for replacement filter caps and I don't see any that match the specs for these caps as described in the instruction manual. That's usually the case for these types of caps in vintage electronics.
I can get a NOS 290-0571-00 from Sphere Research Corporation, but they are pricey with shipping and I'd rather replace with a new modern cap if I can find one that's a good fit per the specs.
Does anyone have a recommendation for the power supply filter caps replacements?
