Author Topic: Tektronix 5006 DC power  (Read 501 times)
Offline tonyc
« on: July 15, 2016, 07:29:53 am »
My 5006 stopped working a couple of weeks ago. When I turn the power switch on I still hear the beep sound but no DC power come out of the slots. I know the AC power is good because the DMM module uses AC power and still works.  Does anybody know what are the usual culprits for such problem?
Offline BFX
  • Country: sk
Re: Tektronix 5006 DC power
« Reply #1 on: July 16, 2016, 05:21:37 am »
I think you really need take apart this guy and measure something   :-DMM
A few photos will be helpful  8)
Online David Hess
  • DavidH
« Reply #2 on: July 16, 2016, 06:48:56 am »
In the TM5006, the DC power is provided by a switching power supply while the AC comes from a line transformer.  Obviously there is a problem with the switching power supply; the primary suspect is the aluminum electrolytic capacitors which are probably worn out with age.
There is no beeper so I assume the beep is coming from the switching power supply when it tries to start.
