Hi:
First of all, allow me to concede that I was a dumb ass...I bought this thing off of eBay, trying to shave off a few dollars versus a new one...this one is apparently a return, and I think I know why it got returned...This is a link to the new one I should have bough...
https://www.ebay.com/itm/TIG-welding-machine-200A-inverter-tig-pulse-welder-ARC-digital-control-3-IN-1-/152619468542This is a rather sophisticated little TIG machine, highly programmable in terms of giving very precise control over the current going into the workpiece. This, of course, makes it obscenely complicated by the standards of a welder. At least five or six circuit boards. :-/
So, I plug it into a known-good 50a 220v outlet and it powers up normally. The fan makes the requisite wooshy sound, the front panel lights up and seems to be behaving normally. So I set it to MMA ("stick") welding mode, hook the ground clamp up to the utiilty trailer I am going to weld up, swing down my helmet, and...
<bzt>...makes a welding noise for about 1/50th of a second, and the unit shuts down.
I cycle the power switch...nothing. I unplug it for a while, then power it back up, and the fan and front end power up normally for about a minute, then it shuts itself back off again.
Now, I have it plugged in with the covers off...same behavior: powers up for a minute and then powers itself back off. When I cycle the power switch now, I hear a faint <tick><tick><tick> sound from the lowermost board, which is the power supply. It sounds a lot like an old mechanical clock running.
I leave it plugged in and leave it for awhile and it powers back up for a minute and shuts down. Interestingly, if I leave it powered down for just a minute or two, it will come on for a few seconds and power itself back off...As if something is heating up and then tripping, and then cooling and resetting...?
I have written the manufacturer but have no idea what kind of factory support I am going to get for this thing and have already resigned myself to having to repair it. If somebody could provide some ideas what these symptoms correspond do, I would very much appreciate it.
-Tom
