First of all hi everyone,
I'm following the EEVblog forum for several years as a guest, and of course I'm watching dave's videos regularly.
As I got my hands on a dumped Weller WD1 for 20 € I thought I will give it a try, as there was no stated/indicated error.
By powering up the solder station without a soldering iron attached I get the first attached image below, which looks good to me at first glance.
Should the display should show even more during powering up?
After powering up, the display shows the icons in the second attached image.
As far as I can remember, the display should show at least the three set temperatures (I, II, III). So it seems something is messed up.
I measured the 12 VAC as well its rectivied ~16VDC representation, used to power the front/display PCB. I measured the output voltage of the 7805, which is bang on.
When I'm pressing both error buttons (both buttons to the right of the display) for 2 seconds or 4 seconds, I'm not able to enter the setup mode for setting up the special functions, as described in the manual.
So I assume the MCU (PIC18F6622) is somehow damaged, although I cannot see any physical signs that the MCU has been damaged, see third attached image.
Can someone tell me if it's the MCU? I have seen in reply #66 there is the appropriate HEX file available. I have a PICkit 3, so flashing a new MCU or "reflashing" the current one shouldn't be a problem.
Is there something I have to keep in mind during flashing, or has anyone experience with the provided HEX files (do they work as expected)?
I would appriciate any advise.
BR
PS.: it seems I'm not able to insert the images within the text.
