Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
What did I fry to make all DC voltages and resistance read negaitive ?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: What did I fry to make all DC voltages and resistance read negaitive ? (Read 299 times)
lordvader88
Frequent Contributor
Country:
on:
March 16, 2018, 12:43:14 am »
I have a $10 XL830L which is a clone of a DT830
x
it seems, with ICL7106 and ICL7107 (1 is LCD driver). On mine they are integrated and under a blob.
This thing runs off 9V, and I was powering it off a 12V SMPS, into a LM317 to get 9V. (I meant to be using a linear transformer, but wasn't)
I was de-soldering a SMD LED with a grounded soldering iron station, and for what ever dumb reason I used the COM DMM tip to get the LED off. I think it was on either 20VDC or buzzer/diode tester. And 5-6 times the LED glowed about as bright as maybe 0.5-1mA would cause. IDK if I also touched the COM tip to the soldering directly.
And then later when I went to use it, all voltages are reading negative. With no input, it reads ~-6.7v, or -0.67, or -0.07 as I switch voltage ranges. So a 9V battery reads as -6.7+9=2.3V
The resistance reads as negative as well.
Here's the basic schematic for these clones
http://indexxit.com/wp-content/uploads/2017/11/cute-using-multimeter-digital-schematic-diagram-masl-simple-circuit-dt830b-pdf-dt9205a-with-lcd-hd-44780-dt9208a-dmm.gif
and the ICs
https://www.intersil.com/content/dam/Intersil/documents/icl7/icl7106-07-07s.pdf
No sign of damage at all on the SMD stuff.
Logged
Chris56000
Regular Contributor
Country:
Re: What did I fry to make all DC voltages and resistance read negaitive ?
Reply #1 on:
March 18, 2018, 07:53:26 am »
Hi!
I think there's an internal short or low impedance between Analog Common (Pin 32) and V- (Pin 26) within the '7106 IC - this will pull all the I/P high and reference circuitry to approx. - 6.5 to - 6.8V with respect to the Input Low, which the cause the A/D converter to read what you're getting - as the meter's one of those with an epoxy-blob all you can do is bin it I'm afraid - these things can be bought from China for the price of a Morrison's cafe sandwich (with free postage !) on fleabay these days!
Chris Williams
Logged
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
wraper
Supporter
Country:
Reply #2 on:
March 18, 2018, 08:07:19 am »
They are both basically the same ADC except 7106 has LCD driver but 7107 LED driver built it. It's impossible to have both in one circuit.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
