Author Topic: Wii U Repair, No Power  (Read 23109 times)
Offline gudenauTopic starter
« on: July 08, 2017, 04:17:26 pm »
I have a Wii U that does not power on. I checked the voltage on the board right where it connects to the power adapter and it gets ~14v. I also had someone check a working one for a power rail by the CPU that was 0v on my board, she had 1.5v. This was right after what looks like inductors to me right overthe giant package.
I am not too sure whereto look, I've checked a few resisters and caps for shorts and open circuits and the all look fine.
Sadly I only have a crappy multimeter that I can't trust a quarter the distance I can throw it.
sudo dd if=/dev/zero of=/dev/sda
Pro tip, do not run my commands!
Online strawberry
  • Country: lv
Re: Wii U Repair, No Power
« Reply #1 on: July 08, 2017, 08:14:58 pm »
Does enable signal comes to this powersupply? Is there any shorts on CPU.. any of these eight powersupply?
How about power button wear-out?
« Reply #2 on: July 17, 2017, 03:43:47 am »
Sorry, didn't get notified...
Not sure of the power supply on the board, but the brick does work.
Per button isn't an issue at all, that's software more than hardware control.
Haven't found any sorts, plus that would probably blow what I think is a fuse or get hot.
Offline BMack
« Reply #3 on: July 17, 2017, 01:55:30 pm »
Did you check that fuse coming off the connector? Check voltage across all those caps and diodes.
« Reply #4 on: July 17, 2017, 02:20:23 pm »
The fuse is in tact, anything in particular I should look for with the caps and diodes?
Offline EPTech
    • EP Technical Services
« Reply #5 on: July 17, 2017, 05:19:16 pm »
Hi there,
Those inductors you mention are indeed part of the supplies for the central processor. I would start by measuring whether there is voltage across any capacitor on the output of the step down converters, that is, on the 'big' capacitors near the inductors. IF you do not measure any voltage there, check whether there is voltage on the inputs of the step down converters, that is, on the brown, smaller, ceramic packages near the supply. If there is voltage on the ceramic input capacitors, but not on the bulk output capacitors, that particular supply may be switched of or defective. There usually is an enable signal on the control IC's, check the data sheet.
If none of the input capacitors have voltage on them (after pressing the power switch) you may have failure on the main supply or some standby power circuit. Without a schematic I cannot tell whether the standby circuit is implemented in HW or SW in the main processor or some other peripheral processor.
Happy hunting.
Kind greetings,
Pascal.
« Reply #6 on: July 19, 2017, 04:17:58 pm »
Hi there,
Happy hunting.
C1428 has 0v, could that be the fault?
Offline abraxa
  • Sigrok associate
« Reply #7 on: July 19, 2017, 04:51:46 pm »
Certainly. However, we don't know which cap is C1428 on the board. Is it an input or output filter cap of the voltage regulator circuit it's a part of? Pictures would be best, of course.
« Reply #8 on: July 19, 2017, 06:18:06 pm »
The cap in red is C1428.
Offline Armadillo
« Reply #9 on: July 19, 2017, 06:31:58 pm »
You can't measure it that way; C1428 and C1429 are in series. If you want, you should measure both ends of the caps.
Measure it per the diagram attached., what is the voltage?
« Reply #10 on: July 19, 2017, 06:34:09 pm »
~14.5v, and when I looked at the board some more the 0v cap is between two grounds. Smoothing I guess?
Offline Armadillo
« Reply #11 on: July 19, 2017, 06:49:26 pm »
The first 2 capacitors and the line choke inductors you just measured forms a filter. Nothing wrong with that.
The typical buck converter are those in the pictures. You should be measuring the buck voltages. But You need to take one close up photo so that I can see the IC and so that I can tell you how to go about.
I hope someone with the board can help you out actually. I don't have the board.
As you have little background in troubleshooting, someone with the board and expertise can be a great help here,
Take the one with the arrow.
Or you can take your friend board and compare Pin to Pin. Put meter to voltage mode. Hook Black to Ground, and then use the Red measure pin to pin of each of the IC and compare with your friend good board.   :D
Edit: While you do that, careful not to short out your friend good board, so that you can return her in good piece, yeah;
« Last Edit: July 19, 2017, 07:00:01 pm by Armadillo »
« Reply #12 on: July 19, 2017, 07:03:37 pm »
I take it the strange dual triangle thing is a brand?
Offline Armadillo
« Reply #13 on: July 19, 2017, 07:45:00 pm »
Those IC you mark are mosfets.
Apparently the power management IC must be somewhere else.
Anyway;
Measure the blue arrows shown;
This is typical measurement, so you measure the capacitor to identify which one has no voltage.
Also the 5066 controller as attached.
« Last Edit: July 19, 2017, 07:50:09 pm by Armadillo »
« Reply #14 on: July 19, 2017, 07:48:48 pm »
Anyway;
They are both 0v.
Edit:
There is a chip labeled "LV5065\n2UNQ" directly on the other side.
Offline Armadillo
« Reply #15 on: July 19, 2017, 07:52:48 pm »
Anyway;
They are both 0v.
Edit:
All the 5065 , 5064, do similar measurement at the capacitors.
Hope you will arrive at the big one supplying all these smaller ones.
Measure Pin 1 and 8 of the mosfet, do you have a voltage there. ?
I think pin 2 and pin 4 is connected [mosfet] together, is it? can you trace this pin to a bigger IC.
« Last Edit: July 19, 2017, 07:56:18 pm by Armadillo »
« Reply #16 on: July 19, 2017, 07:56:15 pm »
Anyway;
They are both 0v.
Edit:
None of the larger caps have voltage expect the one close to the power input.
Offline Armadillo
« Reply #17 on: July 19, 2017, 08:04:06 pm »
There is a fuse that look at photo but mark 10A. Power off, measure the resistance across it.
Never mind you measured it just now.
« Last Edit: July 19, 2017, 08:06:59 pm by Armadillo »
« Reply #18 on: July 19, 2017, 08:05:30 pm »
About 0?.
Offline Armadillo
« Reply #19 on: July 19, 2017, 08:08:41 pm »
About 0?.
Yeah, I know.
Can you answer above questions completely regarding the mosfet voltage and the tracing pin to device.
« Reply #20 on: July 19, 2017, 08:30:05 pm »
About 0?.
Yeah, I know.
Does this help?
Anyone on dial-up would hate this thread. :-P
Offline Armadillo
« Reply #21 on: July 19, 2017, 08:42:25 pm »
do you have a logic probe? or oscilloscope?
For all the 0 volt you indicated, measure the mosfet Drain to Ground point, any voltage there? Either there is no pulse to the gate or no supply going into the Drain. Can you confirm  any?
For all the 5064, 5065 5066 controller, so can I assume all OK supplying voltage?
« Last Edit: July 19, 2017, 08:46:41 pm by Armadillo »
« Reply #22 on: July 19, 2017, 08:44:51 pm »
I only have a crappy multi-meter I am afraid.
Offline Armadillo
« Reply #23 on: July 19, 2017, 08:54:24 pm »
Hi guys, if you reading this, do chip in.
The following users thanked this post: gudenau
Offline Armadillo
« Reply #24 on: July 19, 2017, 09:11:58 pm »
So is there power to the mosfet drain?. With the meter, is there any voltage to the gate.?
« Reply #25 on: July 19, 2017, 09:30:03 pm »
14.5v on the source, 0v on drain and 14v on the gate.
Edit:
If I am not mistaken, that is not correct behavior right?
Offline Armadillo
« Reply #26 on: July 19, 2017, 09:57:15 pm »
I think we are getting somewhere closer to the answer.
Measure again, that the 4808 mosfet as an example, you can see the 2 drain and 2 source and 2 gate.
measure 1 , see the attached.
[*Black probe to the negative side of the capacitor.]
« Last Edit: July 19, 2017, 10:01:13 pm by Armadillo »
« Reply #27 on: July 19, 2017, 10:05:23 pm »
Which cap?
And this is a six pin MOSFET package. Seems to be DDGSDD for the pins.
Offline Armadillo
« Reply #28 on: July 19, 2017, 10:09:32 pm »
Which cap?
Associated capacitor of the buck converter, you just now measure voltage of the capacitor [blue arrow].
D1, D1, S1, G1
D2, D2, S2, G2
« Last Edit: July 19, 2017, 10:11:03 pm by Armadillo »
« Reply #29 on: July 19, 2017, 10:14:30 pm »
Which cap?
D1, D1, S1, G1
D2, D2, S2, G2
I thought you meant the one with the six pins, my bad.
Seems to be zero, and you meant these two joints correct?
Offline Armadillo
« Reply #30 on: July 19, 2017, 10:15:58 pm »
black probe to the capacitor, red probe to each of the ic pins from 1 to 8.
« Reply #31 on: July 19, 2017, 10:18:57 pm »
I got 0v on everything.
Offline Armadillo
« Reply #32 on: July 19, 2017, 10:25:19 pm »
There you go, no supply to the drain from some power supply somewhere.
Now I need you to find out why. So you trace the only the Drain Pins back to the another power supply component, so that we can identify the failing circuit or fuse section that actually failed.
Take a photo of the section.
« Last Edit: July 19, 2017, 10:28:12 pm by Armadillo »
Offline Armadillo
« Reply #33 on: July 19, 2017, 10:43:50 pm »
See example of trace;
For the ohm,  you must power off and measure from the vias [black probe] and find out where it is connected to example RED probe to each of the positive side of the bigger capacitors somewhere [it is bound to be connected to the +ve side of some capacitor somewhere.]
« Reply #34 on: July 19, 2017, 10:51:48 pm »
This seems to be all the connections, up to the chips.
Also, these pins are shorted. D2 and S1 it looks like, is that normal?
Offline Armadillo
« Reply #35 on: July 19, 2017, 11:04:15 pm »
See previous attached, measure the d1. [d2 may not be used, maybe] I don't know,
So let's measure d1 to be sure.
see previous attached example.
Edit: someone with the schematic may be laughing at us. LOL ....  :-DD
« Reply #36 on: July 19, 2017, 11:20:22 pm »
Woops, wrong picture.
Offline Armadillo
« Reply #37 on: July 19, 2017, 11:48:03 pm »
Maybe you should write to Nintendo to ask for the schematic.
Without the schematic, it is definitely very difficult communicating it this way.
« Reply #38 on: July 19, 2017, 11:49:05 pm »
I'll try.
Offline urbis
« Reply #39 on: July 21, 2017, 03:30:46 pm »
No chance of them supplying that.
« Reply #40 on: July 21, 2017, 06:45:47 pm »
Yeap, completely ignored. Guess I should trace out sooner if the schematic myself?
Online strawberry
  • Country: lv
« Reply #41 on: July 21, 2017, 07:22:53 pm »
If that controller is MAX5066
Check enable pins 15 and 28, while enabled should read above 1.225V
Check reference voltage source 3.3V on pin 6, this will indicate that IC is in active state
If there is no voltage on C1244/C1266, using continuity test try to find out where this supply come from all over the PCB(it has internal layers)
« Reply #42 on: July 22, 2017, 01:49:40 am »
I'll check this when I have a chance.
Any tips for board reversing other than use a probe?
« Reply #43 on: July 28, 2017, 01:44:05 am »
I've been slowly reverse engineering some power stuff, what would a decent meter with the beeping continuity test be? It is kind of hard to check the resistance and keep an eye on the probes at the same time.
Online strawberry
  • Country: lv
« Reply #44 on: July 28, 2017, 08:02:54 am »
I am using cheap/decent MASTECH MS8286 . I can not complain about continuiti beep speed. And if has many other useful funtions for repair.
PS.But I am not happy with indication of mismatched test leads
You coud use X-ray for reverse your board :)
There are Dave Jones videos about multilayer  PCB reverse enginering
« Reply #45 on: July 28, 2017, 04:45:25 pm »
I don't have access to X-Rays. At least most of the stuff is on the outer two layers it seems. Over only found two things in the inner layers so far.
I'll check out that meter.
Offline EPTech
« Reply #46 on: July 29, 2017, 11:29:40 am »
Hi there,
I was re-reading this thread and I find it strange that your power input is AC. I do not see a rectifier anywhere. Are you sure the device does not need a DC source? Ask your friends power supply and try.
Happy hunting.
Kind greetings,
Pascal.
« Reply #47 on: July 29, 2017, 04:23:29 pm »
Hi there,
Happy hunting.
It takes DC, there is a power brick.
« Reply #48 on: July 30, 2017, 02:54:40 am »
Anyone happen to have a pinout/datasheet for this chip?
Offline gnavigator1007
« Reply #50 on: August 01, 2017, 03:13:37 am »
This is what I have of the the power delivery, does it look like I missed anything?
I know this is a mess, I based the layout on the PCB and did not bother making it look better since KiCAD does not keep wires when you move a component.
« Reply #51 on: August 03, 2017, 02:23:02 am »
I hate to bump this, but does anyone have an idea with this?
Online strawberry
  • Country: lv
« Reply #52 on: August 04, 2017, 09:43:39 am »
There in sch shoud be connection between upper MOSFET Source and lower MOSFET Drain
Offline stonyme
  • Country: cn
« Reply #53 on: June 22, 2018, 05:59:33 am »
Hello, is your wiiu repaired? If it is, how do you fix it? My wiiu is the same as you are. Please tell me how to fix it. Thank you very much.
