Your code means:
PS2 PRT: 089 (I suspect you typed 1 zero to much)
- PS2 = When the protection function worked due to abnormal voltage in the power supply section. [PS1, PS2, PS3] -> your case PS2!!
- PRT = Protect!!
- 0089 = A/D conversion value of voltage at the moment when the protection function worked (Reference voltage: 3.3 V=255)
Please share your manual, I checked mine and copied the above!
Additional:
Cause: The voltage in the power supply section is
abnormal.
Supplementary information: The protection function
worked due to a defect or overload in the power supply.
Turning on the power without correcting the abnormality
will cause the protection function to work in 1 seconds
and the power supply will be shut off.
I just copied all this from the manual of your receiver (5min work) -> now we need your photo's and schematics what you checked and what is found.
PS1/PS2/PS3Power supply voltage (PS) protection detection.
The voltage at 96 pin (PS1_PRT)/97 pin (PS2_
PRT)/98 pin (PS3_PRT) of IC22 are displayed.
Voltage detects
PS1: AC_BL, AC_12, ±7A, +3.3S
PS2: ±12A, +5A, +5VID, +3.3T, +41F
PS3: +5.5V
Normal value
PS1: 29 to 118
PS2: 135 to 191
PS3: 132 to 168
* If PS1, PS2 or PS3 becomes out of the
normal value range, the protection function
works to turn off the power.
