Current measuring has only a limited range as the voltage drop it has must be low so the USB device plugged in still has a power rail within the USB spec. So most of the ADC range is not usable as you only use the very lowest bits, the rest being unusable. Thus you might have 10mV resolution on volts, but the current will only have 10mA at best, and you will only have about 300 counts for current, while voltage will have 350 at a point where the ADC is less noisy as it is near the top of it's range.
Still they do work well enough, I bought 2 and they agree within 2 counts on voltage and 1 count on current. The mystery component is a diode, marked on my one as RA and with IV at right angles on the end. No idea what diode, but it still is readable. According to the one they draw around 10mA to 20mA depending on what is displayed.
