Author Topic: Analysis: piezoelectric air pump  (Read 1860 times)
Online NiHaoMikeTopic starter
    • Facebook Page
« on: June 22, 2018, 09:11:46 pm »
Very recently, Big Clive did a video on a piezoelectric air pump:
I decided to get a 120V version for a simple project I wanted to play around with (atmospheric CO2 sensor) and I decided to open up the plug to analyze the circuit inside. The circuit is basically the same as for the 240V version:
* It has two 2k resistors in series instead of three 8.2k.
* The capacitor is the same but the inductor is 1.4mH.
* The silly 1M across the first resistor is there, along with another 1M across the pump.
* The pump itself measures about 63nF.
Not sure the exact purpose of the inductor. I was expecting it to form a resonant circuit with the pump but probing with a HVP70 probe across the inductor showed almost no voltage. Something interesting to note is that with the probe across the pump, the voltage slightly increases when the output is blocked.
« Last Edit: June 22, 2018, 09:14:43 pm by NiHaoMike »
Offline thm_w
  • Non-expert
Re: Analysis: piezoelectric air pump
« Reply #1 on: June 25, 2018, 09:24:24 pm »
Probably a good pairing with a CO2 sensor to get a faster response and avoid dust buildup. Although if you don't care about response rate much, the air will circulate reasonably on its own.
If you use a PM sensor those will have fans so you can use that to blow near the CO2.
So it really is running at 60Hz? I had just assumed that is far too low for a piezo, at least optimally.
Maybe you can try a higher frequency as suggested in the comments (but wouldn't be at 120V).
    • Facebook Page
« Reply #2 on: June 26, 2018, 12:29:58 pm »
It really does run at the mains frequency. I'm pretty sure the valves limit the maximum frequency it would work at.
Offline james_s
« Reply #3 on: June 26, 2018, 04:45:51 pm »
Sounds a bit like those piezoelectric fans that were around for a while. I was always tempted to get one but they were relatively expensive and I couldn't really think of a good use for it.
Offline corkus
« Reply #4 on: June 27, 2018, 06:52:18 pm »
Very interesting, thanks for posting!
