Maybe would be a best guess but by all accounts any of the carbon filled filaments and even the metal filled ones are poor conductors. Quick check on similar sounding filaments are 10kOhms/metre of filament so for non circuit stuff might be OK. I would have thought that any plastic sitting on a grounded anti static mat wouldn't build up a charge anyway?
If the Aliexpress one is Carbon Filled (most likely) it will chop hell out of your stock nozzle on the printer so add a hardened nozzle or consider the one installed sacrificial. Add to this to get a decent print with ABS you will need an enclosure (not in all cases but a warm to hot room will help) and the other
thing is will the 'ultrabase' stand ABS bed temperatures never used it so IDK? Did a quick check and Ultrabase is fine to 'great' on ABS
And apart from being a bit of a soggy blanket welcome to printing when your toy arrives
