Author Topic: 4mm sheath binding post  (Read 5864 times)
Offline electrolustTopic starter
« on: May 31, 2017, 12:47:04 am »
Does anybody make a safety/sheathed banana jack binding post?  The type that are on a solderless breadboard, but a safety jack instead of a normal banana jack.
Offline floobydust
Re: 4mm sheath binding post
« Reply #1 on: May 31, 2017, 02:25:55 am »
You mean a 5-way binding post with safety jack? Or a chassis-mount safety banana jack?
I would say you won't find both- because there's no safe way to tie in/bind flying leads, so what was the point.
http://muellerelectric.com/product-category/banana-plugs-jacks-binding-posts/banana-jacks-bj/
« Reply #2 on: June 01, 2017, 12:15:40 am »
good point.  in theory you could have the flying leads attached first, then you can plug and unplug banana.  but i guess this product isn't really wanted by the market.
Offline macboy
« Reply #3 on: June 02, 2017, 03:53:52 pm »
You mean like these right?
They exist. Good luck finding any for sale. (if you do, let me know! I want some!)
« Reply #4 on: June 02, 2017, 04:50:48 pm »
yes like that!  come to think of it, my power supply has those as well.  so someone must have a source for these.
Offline floobydust
« Reply #5 on: June 03, 2017, 01:43:19 am »
I looked again at Pomona, Mueller, Neutrik; Most are for loudspeakers. I think they are custom for power supply manufacturers.
Found these on Aliexpress but not really shrouded.
Offline komet
  • Shenzhen Retroencabulator Mfg. Co.
« Reply #6 on: June 03, 2017, 07:10:00 am »
https://www.reichelt.de/Buchsen/SAB-2640-LK-RT/3/index.html?ACTION=3&LA=2&ARTICLE=160494
I believe they double as binding posts but am not 100% certain.
« Reply #7 on: June 03, 2017, 08:22:56 pm »
Sorry to say that they're not, they are just designed to be mostly mounted in front of the panel.
« Reply #8 on: June 14, 2017, 08:25:09 pm »
bump.
No one has a source for these?  Looking around at power supplies, even fairly cheap ones, these are a common part.
Offline thm_w
  • Non-expert
« Reply #9 on: June 14, 2017, 09:47:02 pm »
Do you care if its actually insulated, or do you just want the shielded plugs to fit?
This looks like there could be space on the sides: https://www.aliexpress.com/item/M4X36-pure-copper-terminal-4mm-banana-plug-20A-binding-post-Banana-plug-connector/32803471963.html
But might not be long enough.
Another thread here: https://www.eevblog.com/forum/testgear/binding-posts-that-accept-shrouded-4mm-plugs/
« Reply #10 on: June 14, 2017, 10:03:44 pm »
Found the Multi-Contact (Staubli) SPK4, which has an insulated cover over a bare wire insertion port.  So, you can't come into contact with the bare metal of the binding post, but still you have to insert a bare wire so not sure how useful the insulation around the post itself is.
$10 ea wow
« Reply #11 on: June 20, 2017, 04:21:03 pm »
If money is no object, then HP Keysight now have this style of binding post and they are available as a spare part.
Binding post from Keysight
Part Number: E3640-60019
GBP 17.66
The following users thanked this post: electrolust
Offline tooki
Offline bateau020
« Reply #13 on: March 10, 2021, 10:36:05 am »
Nice find. I will try them out. A shame they are only available via digikey in EU. Or have you found others?
Offline tooki
« Reply #14 on: March 10, 2021, 11:52:07 am »
Other resellers? No. But at least it’s DK, since they ship to Europe quickly, with a low free shipping threshold, and customs pre-cleared.
