You could probably make a hell of a coin shrinker with one of those. I'm no stranger to high voltage stuff but a capacitor like that even makes me nervous. There is no second chance if you have an accident with that. It's likely to turn whatever body part contacts the terminals into a pulpy mist and you'd probably be dead before you hit the ground.
You could but the secret to that is the same as the secret to making a good aluminum can crusher. You need a switch that will go from on to off in a fraction of a microsecond.
People have tried to build can crushers with SCRs but they take for ever to turn on. (milliseconds) during that time they operate in a linear mode and much of the useful energy is converted to heat.
In the 1980s the Russians were trying to build a a capacitive discharge EMP generator.
They tried all manner of switch mechanisms They settled on a ballistic switch, the moving contact was driven home with explosives, a compressed gas discharge system might have worked as well.. Both systems eliminate the rise time issues that exist with SCRs and other thyristers.
I don't know if it is still up there...
There was a YouTube video of a guy who built a can crusher with a big cap and a spring loaded switch... His system had other problems like the wire size used for the coil was too small and on one occasion his coil blew up.
This stuff has fascinated the hell out of me, I use to work next door to one of Maxwell Industries plants. They built an EMP generator that took a city block offline one day due to ineffective shielding. They also built a gun that shot a .4" aluminum covered Mylar bullet that could penetrate 3/4" steel decking. There was an article in the local paper about that gun, then nothing heard.... Makes me wonder if the third generation of that gun isn't orbiting up in space above us...
Some day I am going to build my can crusher.
