I have a radio shack
digital soldering station. I want to replace the iron but I'm having trouble figuring out which one will be compatible. The
manual says it is 28v/60w. The iron connects to the station using a 5 PIN 180° DIN connector.
I'm measuring about 12Ω between pins 1 & 4 (black and white wires) and 1Ω between pins 5 & 3 (red and yellow wires).
The green wire is earth ground and connects to the metal part of the iron case.
Would
this work if I replaced the connector, or can someone help identify one that would work?
