Feel free to shoot me for starting a new thread or not reading the one post in another. After reading through the threads it seems that the internal guts of the 858D seem to vary significantly from one unit to another, including different MCUs and different board designs.
I'm thinking of buying one. I'd like to buy one that meets the following criteria:
1) US plug/120V
2) Constructed properly (fuse on 'hot' line, and proper ground), and good construction practices -- I can probably fix any thing, and I know enough to double check all the grounds and the fuse -- but I'd prefer to not have it die because of a wire broke and then it over heated and caught on fire because a wire was badly run and mechanically stressed.
3) AVR MCU -- It'd be nice to be able to hack it, since it appears there are significant improvements available, but it appears there are options even for the non-AVR ones. Also, does any one know if different MCUs have different performance since presumably their firmwares aren't identical.
I was under the impression the YouTue 858D+ is the best bet, until early in 2016, but a year later not so much. The Yihua units seem to have collected a bad rap. There are a host of these units on eBay for around $30 (shipped, oddly, from the US), including a couple unbranded one, Ansai, Gaoyue (its yellow!), Yihau, Youyue, Uyue, WEP.
