Author Topic: Adhesive death. The eletrofita system  (Read 8089 times)
Offline PTR_1275Topic starter
« on: January 09, 2016, 09:14:36 am »
I couldn't see this mentioned previously on here. I saw a video of this and at first glance it looks like a reasonable idea until you think about it for more than a millisecond. They are feeding mains voltage through adhesive copper strips (to new outlets or light switches etc...), then put some tape, plaster and paint over it.
I don't see how this would be legal anywhere due to the lack of insulation / physical protection. What's other peoples thoughts??? It looks to be Brazilian but I couldn't get their website to load. Heaps of images in google though to give you an idea. Below is one of their videos.
Offline German_EE
Re: Adhesive death. The eletrofita system
« Reply #1 on: January 09, 2016, 09:52:22 am »
This would not be my chosen way to install mains wiring and I doubt that it would pass a safety inspection anywhere in Europe. However, if that mesh that they put over the copper strips was kevlar it might provide some protection.
Nice idea for low voltage wiring though, I may experiment.
Warren Buffett
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #2 on: January 09, 2016, 10:21:12 am »
Just stupid if it was mains, it would not be legal here and would kill the next person putting in a fixing to mount a picture, these people should learn proper cabling techniques.
Offline Falcon69
« Reply #3 on: January 09, 2016, 10:28:37 am »
ya, that won't fly here either, not even low voltage.
Mains needs to be buried in a wall as Romex or wrapped in conduit. And it needs to set back no less than 1 inch from the wall. So studs need to be drilled enough to allow that before you run the wires through. In some cases, a Metal plate needs to be placed over the hole on the stud before drywall is placed over it. The set-back one inch is mainly for drywall screws not getting close to the wire. However, As a cabinetmaker/installer/remodeler, I'm not gonna lie....there's been a couple times I've hit 110 with my drill screwing in a 3 inch screw to mount a cabinet.
Speaker wires you can do what that guy in video is, but to mains?  That's just crazy.
Offline mroz
« Reply #4 on: January 09, 2016, 10:56:40 am »
The idea itself seems interesting, but the implementation is not.
A i see there, the copper tape is strapped directly to the wall. What happens you pour a liquid over that and then touch it? The idea is, I suppose, that this way those wires may be very thin, but i don't think its a good idea to put 230VAC there.
Those were the cons, but what if we do it properly? For example if we add a proper insulation tape below and above the copper track? This should be sufficient (see the image https://dl.dropboxusercontent.com/u/7430474/Untitled.png ). The problem is this way it will get much thinner (maybe 3 times) so, its gonna be much harder to hide it behind a paint.
Moreover, according to a PCB trace width calculator included in KiCad, a 0,035mm x 11mm copper trace should be able to conduct 5 amps at 5meter distance with only 5.6W loss ( compared to 5 amps * 230 V=1150W its nothing) and 5 degree temperature rise. Calculations done for internal PCB trace.
I am not talking about passing any legal things. That idea is a neat hack that can be used to provide power where its required without using power cords (no go down, below your bench and count the number of power cords).  It is simple and elegant. You can tape it over furniture(for example on the back of a shelf) to provide power to an equipment stored in it. I like it.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #5 on: January 09, 2016, 03:25:03 pm »
The concept is great for applications that allow it. I've seen it for ethernet cables, though I doubt that will work for distances.
Such as ceiling lights where the initial power box is meters away and cables are ugly.
If you were to use it for high voltages, then at least stack the conductors and surround them with earth foil. That way it will trip the RCD when punctured. Just as in outdoor cable.
Offline Brumby
« Reply #6 on: January 11, 2016, 05:42:01 am »
... when punctured.
Aside from the fundamental heebee jeebee reaction from laying out mains like that, that was my first concern.  It wouldn't take a lot of imagination to picture some metallic component of some shelving, for example,  that was set against the wall to penetrate down to a conductor.  It could be through wear where the shelving was resting against the wall and there was movement in the floor or an impact by somebody bumping into it.  Take your pick of scenarios that could follow.
Also, because it is essentially invisible, subsequent maintenance actions enter a whole new realm of risk.
IMHO, there is a requirement for 'elevated care' in such an installation for things to not go south, that is just simply unrealistic.  I'd only suggest it for low power speaker wiring at best - but for mains power ... forget it!
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #7 on: January 11, 2016, 09:31:07 am »
It starts badly - no provision for an earth/ground connection at all.
+1 to to all the earlier comments
Don't ask a question if you aren't willing to listen to the answer.
Offline hibone
« Reply #8 on: January 12, 2016, 10:57:47 pm »
Darwin award here... No doubt...
If I am not mistaken that tape was meant to wire the loudspeakers or to carry signals whatsoever...
The author is probably laying down a trap for it's mother-in-law...
Irony is, electrofitas sounds much like a contraption for electro-neophite, thus it matches with the content of the video...
 :clap:
Offline Macbeth
« Reply #9 on: January 12, 2016, 11:49:59 pm »
Never mind the Elf'n'Safety, it looks like even more work than just doing it properly. Also, maintenance? Utterly pathetic. I imagine this is on an "As seen on TV" shopping channel?
Offline tooki
« Reply #10 on: January 13, 2016, 01:03:34 am »
I first saw this system as speaker wiring.
The mesh tape looked like the fiberglass mesh tape used for patching and joining drywall sheets (at least, how it's commonly done in USA). I imagine kevlar tape would require those specialty scissors used for kevlar string.
Offline Godzil
    • My own blog
« Reply #11 on: January 13, 2016, 01:15:15 am »
I suspect this is the sort of video that run on POS. (Considering the quality it's coming from a VHS)
When you make hardware without taking into account the needs of the eventual software developers, you end up with bloated hardware full of pointless excess. From the outset one must consider design from both a hardware and software perspective.
-- Yokoi Gunpei
Offline lintini
  • Country: br
« Reply #12 on: December 15, 2017, 06:59:59 pm »
It's a Brazilian invention I suppose and I can tell you I love it - I have it in my house. It delivers 220Vac to five 5W light spots through a 10A ON/OFF switch. The insulation is tough enough to withstand some damage and it gets invisible when applied correctly. It's solder-able and easy to work with.
C'mon guys. Are you really concerned of puncturing it with a nail or something? What common wire wouldn't be damaged? You would be shocked for sure if you stab it with a sharp knife -  as any wire in the world.
Every country has its own standards, definitely. Some are exaggerated as we know :)
And yes, some types come with an extra flat wire for grounding.
« Last Edit: December 15, 2017, 07:01:39 pm by lintini »
Online Kleinstein
« Reply #13 on: December 16, 2017, 10:20:45 am »
This tape looks like a perfect match to the electric shower head.
There is some protective (transparent) film over the copper at least - so there is a little more insulation than just the plaster and  paint.
A strange point in video is that they only fixed the lamp with tape - this would not last very long.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #14 on: December 16, 2017, 10:31:34 am »
I was expecting better integration with the fixtures, having the foil go straight into a socket rather than having to transition to a wire first.
At the very least I'd expect it only to be legal to use in an installation with an RCD and suitable overcurrent protection. A layer of earthed copper or ali. on the front, combined with an RCD could provide reasonable protection against piercing.
I've seen a lot worse.....
Day Job: Mostly LEDs
Offline agehall
« Reply #15 on: December 27, 2017, 04:20:59 pm »
This is quite honestly one of the worst inventions I've ever seen. They certainly deserve a Darwin Award.
