Well I just had a really interesting on site demo of the Tek scope. (Thanks Tek guy, if you happen to read this.) The guy had a pretty good sales pitch.
Some of the cool new stuff and info:
1) The Tek 3000s were introduced in 2008, so it's not really that old. The previous generation that the 3000 replaced is about 15 years old now.
2) The newer 3000 series tek scopes are software bandwidth upgradable all the way to 500mhz. The older ones were not calibrated for anything other than the set bandwidth, but the newer ones, starting with SN C02 are factory calibrated for all bandwidths and just require a software upgrade. No sending it back required. They just started doing that, probably to compete with the Agilent's upgradability. There is no upgrade path from DSO to MSO for these models though. He confirmed a very small percentage of people actually ever upgrade anything. That is at least an option now though. I guess if you have an older serial number you can still send it back and have them upgrade it with the new calibration.
3) The decode expansion modules, which are those stupid physical hardware key token things to plug into the side by the top, can be stored digitally in the scope so you don't have to have them physically in there to use them and potentially get them stolen if you are in that sort of environment. The hardware token thing is deactivated when you load them on the scope though, so you can't install the same token in a bunch of scopes. Not that there is much he could do about it, but I did complain that the modules are ridiculously priced for the cheaper units, being over 25% of the price of the whole scope, per expansion module.
4) He said that they recently did a detailed side by side comparison with the Agilent 3000x series and a bunch of that info will be coming out soon.
5) He made a point of Tek having some big company syndrome when it comes to advertizing and they are just now starting to learn how to use things like youtube to help advertize their stuff to the middle and lower markets. So I guess we should be expecting to see more stuff like that.
6) The scope comes with a lite version of labview to help automate stuff. That could be super useful if you had labview experience and wanted to set something up quickly.
Some impressions, understanding that I still haven't played with an Agilent or Rigol yet, so this is just my impression of the Tek having played with it for about 30 minutes.
1) I didn't have any of the digital mixed signal stuff going on during the demo and I didn't see much lag in the interface. It seemed pretty responsive, even on a long timebase at full memory. Could the digital+MDO stuff have been causing the lag?
2) As far as usability of the interface, I thought it was fine. There are a lot of deep menus, but there are also a lot of features. Nothing was too outrageously placed, menu or button wise. Things that were non-intuitive like having to turn a knob instead of push a button to set something was pretty well noted what you had to do on the screen menus. The panel buttons were fine as far as amount of them, placement, and feel. Nothing that would drive me crazy on a daily basis. Using anything this complicated is going to take some getting used to but I didn't see anything that would be long term a deal breaker.
3) I'm not sure how much I like the wide screen non-square boxes, but it didn't seem like something that would drive me crazy.
4) The triggering looked pretty nice. Lots of options for setting up ranges and conditions. I could see that being useful.
5) Having the measurements use the full memory instead of just the screen data (I think he said like 1000 points on the Agilent) would be nice. It seems that once you have all that data in a digital format, which these scopes do anyway, it would just be a software thing to do math over the full memory. I wonder what Agilent was thinking restricting themselves like that, and why they don't write some new code and patch in those features since it's something their competitor is rightfully advertizing as an advantage.
So to sum it up, first of all I'm not a Tek fanboy. This is also the first scope in this class that I have physically played with. I'll hopefully get the others here soon. On a purely technical basis, I didn't see too much wrong with the Tek in the brief time I played with it, and I do like the fact that the memory/sample rate isn't split between the channels and the math is over the whole memory. I may request a demo unit to keep for a while if I'm still undecided after seeing the Agilent and Rigol, but I don't think I'd regret going with the Tek and using it on a daily basis. If I consider the equivalent upgrades to the Agilent to bring it up to about the Tek specs (500USD for the memory upgrade to 4meg, and 400USD for the lan/VGA module) and ignore the wavegen, the Tek list price of 4050USD isn't too outrageously priced. I haven't got their actual quote yet, but it should be better than that.
When I mentioned EEVBlog, he only rolled his eyes a little. He did say he knew of it and that he was impressed at Dave's ability to review things like the zipper on the case the scope came in and make it sound interesting. I had to chuckle.
Just some more info for everyone.
