I was annoyed that my $20 Aldi Traveler Battery Pack only showed 3 of 5 battery level LEDs when fully charged, and this is the same for everyone. It turns out that the LED to the right of the "Full Charge" LED was a red Battery Low LED. Very strange layout. So that means 4 and not 5 LEDS should be on when it is charged.
So I decided to see what is going on, and to fix it if i can.
Here is the PCB. The battery charger IC near the mini-USB input is unknown. They have sanded the top or something. It does have "TP4XXX" (x's are unreadable) and below that "1128" or "1123" . Anything else is wiped out. I was unable to track down any charger IC that matched.
The 5V 2A boost regulator is based around a 5 pin Seiko S-8357F50MC-MHJT2G (U1). If you are wondering why the part number is so long, they make a massive number of very slight variations, so that the final circuit is as simple as possible. In this case only 3 connections are needed - one to 0V, one to the gate of the P-Channel FDS4435 FET (U3), and one to the 5V output. It runs at a fixed 600KHz frequency. Output was 5.05V no load, 5.00V with 2A load. The other 8 pin mosfet (U2) is an IRFT807Z N-channel for switching the output power on and off.
There is another 14 pin IC with the top milled on the left that is some kind of control IC. It may be a micro - I am not sure. It does the ON button, and it may monitor the output current.
In the top photo, the LEDS have been bent over so I could scan the board.
The tool that punched the PCB out was very blunt from the look of things.
The LED level indicator circuit surprised me. All charger chips have a LED indicator output to indicate the charging status, so you are going to use that? No, the designer had a much better idea. Use LEDs for measuring the battery voltage.
Here is the circuit:
A weird circuit. The problem was the charger limits the battery to 4.2V, and yet the 4th LED turns on at 4.3V, so it never turns on. There was no way to see if the batteries were charged or not. Having taken it apart, I now realize that if the 3rd LED is fully on, it is close to a full charge, but other purchasers were charging for days, wondering if they had a faulty device.
I imagine the designer had the 4 LEDS working perfectly in prototype in the lab, and then different LEDS were purchased for production to cut costs. So much for LEDS as precision voltage references!
I changed the 150 ohm R15 to 130 ohm, and now the 4th LED is just coming on between 4.1V and 4.2V. I am happy now.
The RED led is controlled by something more accurate - probably from the charger IC - and when it is on, the USB output is switched off.
Overall, a good deal for $20. Two 3.7 AH batteries, 2 USB outputs with a genuine 2A maximum total output with great regulation. 10 adapters. It now works very well. Some of the newer phones will charge very quickly if the USB can source over 500mA, and I could charge my phone at least 3 times from the battery pack.
Richard
