Short experience with the Panasonic:
Pro's:
-lays good in the hand in both physical settings
-The torque stop is great, I was used of the rattler noise in my bigger screwdrivers but this one just plain stops, it cuts the power to the motor when the torque is reached, it has the experience of a pro factory screwdriver.
-When it stops you can directly use the screwdriver manually to fasten even more if required.
-Fast! in the high setting 600rpm , more then fast enough for me
-excellent batteries (Panasonic quality)
Con's:
-Torque has wide setting but even setting 1 (least torque) is already quite sturdy so I would rather have had a 0,1 - 4 then the 1-20 there is now but OK it is workable.
-inserting screws back in the plastick holes needs a short manual cc rotation till you feel the start of the thread, this is much easier with a handscrewdriver then with this large thing.
-no drillholder included
