A while ago I picked up a Micro Lambda MLSL-0609 synthesizer. It's rather old (date code 0138), but I have a datasheet and programming info from the same timeframe. There are two commands that you can use to program it. The 'C' command tells it how many frequency steps to go. The 'F' command allows you to enter the frequency directly in MHz.
I wrote an Arduino program to control it and found that the 'C' command works. The 'F' command is accepted, but it doesn't really work. There doesn't seem to be any reference frequency that gives a sensible output.
I think that these units are customized at the factory. Does anyone know if the older units or some of the customized units didn't support the 'F' command?
I haven't contacted Micro Lambda because I'm not their customer and never will be so I don't want to bother them. Also, since my program works with the 'C' command, this is really just out of curiousity.
Ed
