Hi, I know the OP had been warned not to alter the spacer or nipple covering the bottom part of the heating element but I can confirm it is safe to do so and will drastically improve the iron’s thermal transfer performance. I, too, had thermal resistance issues with my own “Hakko 907” style clone iron which, as mentioned by many others, is due to the air gap between the top/sides of the element and the hollow part of the tip. On my iron, the air gap between the top of element and the deepest hollow part of the tip was a whopping 2mm! I really had no choice but to trim the nipple down. I did this easily by basically grinding down the nipple using my Dremel. I also bought some 0.1mm thick copper foil to make a shim to fill the small gap between the sides of the element and tip.
When reassembling the iron, be very careful NOT to over tighten the tip enclosure. Over tightening it will put a lot of pressure on the heating element since it is now fully touching/mated to the inside of the tip. Just a few turns of the nut by hand until it is snug but not tight will be sufficient.I was amazed at the performance improvement of my iron after these mods were done. I now have no trouble desoldering large heatsinks and large solder joints. My friend, who has a genuine Hakko FX888D, tested out my iron and was shocked that my iron actually performed just as well as his $100 Hakko (I scored my Yihua 852D+ combo unit years ago for a measly $5 at the local flea market...it was labelled as broken but I later discovered it only had a loose sensor wire in the iron’s handle which was easily fixed
). The only issue my friend noticed was that my iron handle got a lot warmer than his Hakko handle. I should wrap some silicone tape to the upper handle but I don’t mind the extra warmth.
I decided to check the difference between the measured tip temperature (I borrowed my friend’s Hakko FG100) and the temperature shown on the unit’s LED display and was pleased to see that it had narrowed down to only 5 or so degrees C. Previously, it was off by more than 20 degrees C! These mods were definitely worth the time and effort. Hope this was helpful.
