I switched from WiFi to homeplug or whatever it's called, and tried two different versions, single phase in a two bed flat with three APs appropriately channelled. Although Homeplug was more reliable than WiFi, it was still unreliable, possibly due to variable loading on the supply, but it also seemed to coincide with darkness, I assume as the S/N degraded due to ionospheric effects in the evening. Like WiFi, Homeplug never achieved its alleged speeds.
The main reason for "copper" was for a more reliable connection to allow centralised backups of a couple of PCs, and WiFi just wasn't working quickly or reliably enough. But nether was homeplug.
Instead, in the end, I laid that flat CAT6 cable tucked under the carpet edges and under the doors between the three main rooms with switched, and added the three APs covering the entire flat with appropriate channel interleaving. I've since moved the same setup to a three bed flat, and it works very well.
In short, save yourself the agro and uncertainty of a half baked solution, and wire up instead.
