Hey everyone, longtime lurker and Youtube watcher, first post on here. Been reading the forums for a long time and watching Dave on Youtube!
So anyway... Now that the hello is out of the way...
I bought an Atten PPS3005S off eBay, brand new sealed box. I know they aren't that stellar but i see a lot of posts of people owning them on here and they seem ok for basic stuff. All i really needed/wanted it for is testing breadboarded circuits before i fire up the CNC Router and mill a PCB to make my design permanent. I was doing it before with a butchered ATX power supply and a couple meters, which then died catastrophically one evening, it was an old old old ATX supply and just gave up the magic smoke.
So anyway fast forward to this evening, i unboxed the new Atten and powered it up, like some have posted on here its a little slow on the button presses but hey it works, the output voltage when set to 5.00v was showing 5.01 on my trusty old Fluke 87, so thats not too shabby i thought. So i flipped the output back off, set it to .500 mA and connected it to a circuit i was testing, total current requirement should have been less than a half amp so no worry. Turned on the output, everything working, looking good. Phone rang, walked away from the bench for about five minutes, came back and the circuit under test was no longer powered, indicator LED was off, then i looked at the supply, it shows 0.21v and 0.266 mA, the CC light is on, i thought uh-oh something in the circuit went kaput and the supply went into CC mode. Well ok so i disconnected the circuit under test and checked everything but everything looked completely fine! So i powered the Atten back up and the display showed 5.00v and .500mA so i figured ok its gotta be the circuit under test right.. Wrong. Even without anything connected to the output terminals when i tap output to enable it the display quickly changes to 0.21v and 0.266mA, no matter what you set it to for voltage or current. I tried setting it to max, 30v and 5A, still when i tap output it goes down to .21v and 0.688mA, its almost like there is a short on its output?
I suspected the cap across the output terminals because a few have posted about that cap being a total POS.. So i pulled it apart and desoldered and removed that cap, tried it again, same thing still .21v and 0.266mA when set to 5.00v and 0.500mA. So i soldered in a brand new Nichicon cap, same result. I have checked all the voltage regulators, mine is the later revision with the machine wound current shunt and silkscreening on the top of the board. The 5v reg is 4.99v, the 12v reg is 11.99, and the other labeled test points are as they should be matching the voltages silkscreened on the board.
I checked everything i could think of, but i can't get it working again. Any suggestions guys??
