Enough mechanical parts there to make at least 4 3d printers, and I wonder if you could use the rotary turntable and a simple XZ movement ( and a lot of conversion from Cartesian to radial planes in the software) to make a 3D printer optimised for circular objects.
Pumps are nice, and the drain system is both simple and likely to not block easily, though looking at the assorted coloured stains and spills inside there has been a lot of oops moments in use, or during maintenance. Would hate to think of the price of the "kit, maintenance, first line" and to the contents, likely it comes in a 10kg box almost as big as the unit. would only be things like the wipe film, ribbon for printer ( at 3 lines per slide it will do thousands and that Citizen printer mech is run at low duty), piping to filters and then filters and such.
Printer will be easy to do self test, take the connector that leads to the main board ( not RS232) and you will find that there is a common, a line feed pin, a on off line pin and then it monitors the busy/online and error light outputs. Hold down line feed ( or short the lot to common) and power it up and after 5 seconds let the lot open, it will print a self test pattern or dip switch setting, depending on firmware version.
