hmm abrasion by dirt ingress I never thought of that.
I obviously would not be asking by the way if my existing cables were not being damaged
and it also protects against UV.
OK so whats the deal with mine applications on these braids then, are they talking about some kind of LV wiring or what? mines are utterly full of abrasives.
they are for sale commercially BTW but this is why i asked.
and you can inspect it still, you would need to remove the clamps and slide it out. i guess its not quick anymore or done as frequently.
I actually do end up using it on gravel and asphalt and woodchips. I try to be civil with it but there are limits to how much attention I can give a cable when I need to do very labor intensive yard work like hedge trimming and stuff.
I will contact tech-flex to see what they say about 'on the dirt' applications, most of their pictures do seem to be centered around protecting elevated equipment. But still a hydraulic hose can easily get splashed with mud and not washed (say on a scoop for a dozer). I wonder if it makes failure rates more.
