Thank you guys. Lots of good info. I pulled the trigger on the JBC DME with the T210, T245, PA120, stands for each, and a handful of tips. I'll post info on impressions soon. It should all be here tomorrow.
Honestly, I will never understand why some people are willing to spend ridiculous amounts of money over soldering equipment!
Essentially, you're paying extra just for the brand name (with no added benefit)
I've used many brands over the years. I currently have a Hakko 951, a Weller WESD51, a Jovy 40, a Jovy RE-8500, an Aoyue rework station, 2 X-tronic rework stations, and honestly several other small stations that worked so poorly that they've just been tossed into our storage room. Here's the rub. With cheap units, you get 100% what you pay for. With mid level units, you get 95% what you pay for (best bang for the buck). The remaining 5% goes to the name. With higher priced items, you get 75% what you pay for. 25% goes to the name and company reliability. Yes, I paid $850 for the DME, but as a business, I know I'm spending $650 for the unit itself and another $200 to buy a product from a company that knows what it takes to be one of the best and does what it takes to stay there. That ensures that my product has been tested, is 100% the quality it should be, will work better than it's competitors, and if it doesn't, they will do what it takes to make things right. It's just like anything else, when the time comes that you need the best, you're going to have to pay for it. Just like anything else. I've had cheap stations start smoking, melt their handle, and all out fail. You can't run a business on that. I've taken units apart to find unrated wiring, loose wires, loose screws, broken boards, cracked heating elements, bad grounds, etc, etc. What happens when one of my offices catches on fire, 3 people get hurt, I have to close it for a month, and then the fire marshal determines the cause of the fire to be a Chinese made pre-heater that didn't pass US electric code? A couple hundred bucks will be the least of my worries.
Here's a 100% true story. Years ago, I had a BGA rework station IR-PRO-SC that I ordered from China. On the forth use, when the machine hit it's peak temperature in the profile (probably about 230 C), it didn't stop heating. It just kept getting hotter and hotter. Luckily, I was standing right there, and when I saw that it had gone all the way up to 270 C, I immediately hit the big, red emergency stop button. Ha, not only did it not work, the temp took off like a monkey out of a box and was now rapidly climbing! Within seconds, my thermocouples near the BGA were reading over 340 C. The board was now flexing from the heat. Damn it if the plug wasn't behind a shelving unit with a bunch of crap on it. All the crap went to the floor and the plug out of the wall. The temp hit over 400 C by the time I got it unplugged. I honestly don't remember the actual temps, but everything got hot enough to completely destroy the board and force use to relabel the "emergency stop" button the "emergency f*** s*** up" button. That situation could've gotten much worse. I later took that unit apart and saw hot cheap everything was inside it. I honestly can't believe I was able to repair the first couple boards with it. $1100 to the trash.
