Hey all,
This is my first post on the forum. I've watched most if not all of Dave's videos and I've got the EEVblog badged Brymen on the way from Amazon as my old Craftsman DMM's display crapped out (and wasn't very good to begin with).
I picked up one of those terribly cheap 862D+ stations with the hot air and iron in one about a year ago, and here's my thoughts on it.
The hot air is surprisingly good. Air flow is controllable, heat is controllable. It overheats a bit on start up, but that's not too big of a problem. Automatically cools off when you set it in the dock (thanks to a reed switch).
The iron however... is a steaming pile. The tips it came with have metal that flakes off on first heating. They do not hold solder AT ALL so to actually make use of it, I have to heat the joint, melt solder onto the tip (instead of into the joint), and then it will transfer enough heat to actually solder. It originally was totally unusable. Tip loose on the heating element, big air gap from the top of the tip to the top of the heating element. Just last night I got it working better by shortening the external tip holder and losing the spacer so that the tip is directly against the heating element. It gets hot fast, and it does seem to be sufficient in power (was able to solder up a KKMoon XR2206 Function Generator kit off eBay with no issues; it has 3 potentiometers with large metal through hole pins to fasten them). The changes I've made to this iron significantly alter it and I seriously doubt it will last like this.
I've determined through much research that this design is a rip off of the seemingly awesome Hakko 907 iron. Upon more research, it seems the Hakko FX-8801 iron is identical as well, differing only by a DIN 6 instead of a DIN 5 with the center pin being there to stop backwards compatibility as it's not connected.
I've found "genuine" irons for the Hakko FX-8801 on eBay for $15USD. From Hakko they seem to be almost the cost of the FX-8801 station ($80USD), which pretty much makes getting an actual genuine iron pointless when I can get the whole real station and not have to muck about with the crappy Zeny (switching from male panel DIN 5 to female panel DIN 6). I do like the idea of everything in one station for space concerns, and the internals of the Zeny are actually fairly decent; iron has got to go.
Has anyone bought the eBay "genuine" Hakko irons and compared with a real one? Any advice for me?
Thanks,
Jim
